Piers at corners of 10’x15′ shed
damunk | Posted in General Discussion on February 19, 2013 12:33pm
Double 2 x10PT frame.  Where should corner of frame land on pier?  It’s a simple gabled shed. 8′ walls w/ 9/12 roof.  Corner posts centered on pier or corner to outside edge of pier?  Or maybe it’s fine either way.
  1. DanH | Feb 19, 2013 06:37pm | #1
    It depends on whether you want to trip over the pier while you're inside the shed or outside.
  2. DanH | Feb 19, 2013 08:32pm | #2
    (There's a slight advantage to having as much of the pier under the shed as possible, since that reduces the surface that can collect and hold rain/snow and promote rot in the framing.)
  3. florida | Feb 19, 2013 08:59pm | #3
    The rim joist should land on the outside edge of the piers. If it were my shed I'd want some intermediate piers in there as well.
    1. damunk | Feb 20, 2013 07:55am | #4
      I was just thinking that perhaps load would be transfered "better" if corner posts were centered on pier, rather than outside edge. You are not comfortable with double 2 x 10 spanning 15'? No live load, really...
      1. florida | Feb 20, 2013 08:13pm | #6
        Not comfortable is a good way of putting it. The Span tables may say it's okay but that's a long way to support any kind of load.
  4. oldhand | Feb 20, 2013 06:32pm | #5
    there are some details missing but,
    If it will store much weight at all I would want at least a center pier as well.
  5. damunk | Feb 21, 2013 07:44am | #7
    double 2x8PT perimeter framing seems fine for this shed.  It's just for garden junk.  There may be a few 100# bags of lawn care stuff but.....have 2x6 joists......The concrete piers are for leveling more than anything else 'cause grade falls away quite quick from "front".  I was mainly wondering about how corners should land on the piers.  And you're correct, this is the max. our town allows w/o permit.  10x16 requires one.
  6. DanH | Feb 21, 2013 08:13am | #8
    Maybe he should use ONLY a center pier, and cantilever the thing. ;)
Fast, Accurate Wall Framing
