Any techniques out there for removing a shower nipple broke off right at edge of the brass 90 degree fitting in the wall. I need something that will fit inside the end of the the nipple and twist it out of the brass fitting.
Inside pipe wrench.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=28191-943-05212
It probably broke because the two parts were corrosion-welded together. You'll want to hit it with Liquid Wrench type stuff and then heat it to aid penetration before you try to get it out.
If using a regular propane torch would be a problem, this little BernzOmatic lighter might do the trick. It is small, but puts out a blue flame like its bigger cousins, only about 3/16" wide and 1/2" long.
http://bernzomatic.com/bernzomatic/consumer/landing/index.jhtml;jsessionid=XKDRJ3FDHM4ACCQIUB2CF3QKBCQGIJCK
I had to deal with that exact situation. What found is that the inside pipe wrench and the screw extractor types ( even an extreme short one for 1/2" pipe) could not go deep enough to grab the broken threads, They kept bottoming out in the back of the drop eared 90.
The shower arm came through the tile of course, so I attacked it from the back side which thankfully was a laundry room so sheetrock repair was more friendly.
Good luck
If you can't find a snub-nosed screw extractor in that size, or cut off a standard one so it won't bottom out in the L, you are going to have to do it the old-fashioned way.
First drill out as much of the busted off nipple as you can without hitting the threads. Then Zen yourself into a nice, calm state of mind and get out a cold chisel and a hammer....
Dinosaur
foolish men call Justice....
apply heat.... heat gun not flame...
internal nipple wrench...
tighten a fuzz first...
unscrew the offending little gasper and go back to work...
If the methods already mentioned do not work for you, a 100% sure way is to drill, then run your tap sizing reamer in, then use your 1/2 NPT tap to lean out what is left.
Probably dont have those if you needed to ask about easy-outs or inside pipe wrench set though.
HF has inside wrenches for under $2 when on sale. Have found if there is extensive galvanic corrosion the drill/ream/tap method is the only thing that does not damage the female thread side (or break off a corroded pipe inside the wall - not fun that <G>).
