FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Plaster and Quick Setting Joint Compound
| Posted in General Discussion on January 4, 2000 11:55am
Have used dura bond quick setting joint compound (20 min.) as a repair for small areas that need plaster repair. Have some large areas right now tho and if it fails it could be significant. Should I put a mesh up first before applying (there is already lathing strips). Any other ideas? Do not want to use 1/4″ sheetrock
  1. Guest_ | Dec 04, 1999 05:37pm | #1
    We use Durabond for large and small repairs. Anything sheet sized we bring in our plaster sub. Try Durabond 90 or D45 for large repairs.
    I would use a mesh, or maybe even a small piece of expanded metal lath. The wood lath was designed for the horsehair coat to tooth into. Then the brown coat bonded to that and lastly the white finish coat.
    Assume a two coat system for large repairs, with mesh first.
    You can also see the Wall& Ceiling website for advice from plaster pros.
    OR hang around , they'll drop by pretty soon.
    1. Guest_ | Dec 06, 1999 05:53am | #2
      *Are you using some kind of bonding agent to improve the chances of the plaster staying put? PlasterWeld is one product, but there are others that work as well and are cheaper, so say my plastering friends. My experience fixing large areas in my old house says that it makes an incredible difference; no cracks in 10+ years where I used the stuff, but the places where I did a "quick and dirty" without it are beginning to crack. For larger areas, I have had good luck with expanded metal lath screwed to wood lath or studs to give plaster extra strength.
Fastening Outside Corner Bead
On an outside corner formed by a double layer of drywall, the corner bead can be fastened without nails or screws.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
