my daughter has just purchased her first home and we have stripped four layers of wallpaper from her daughter’s bedroom walls . my granddaughter wants to paint the walls. can we just prime the walls first and paint. or is there something else we should do? someone mentioned spraying something onto the walls. we need help.
thanks. lana
wash the walls.. rise and do it several more times...
TSP is a good bet here....
prime.. paint...
gotta get rid of the glue..
WOW!!! What a Ride!
Those old plaster walls should be paintable as is. If the surface is pock-marked, you may want to apply a skim coat of plaszter, then prime and paint.
You shouldn't have to prime over the old plaster-type walls in their "original" state.
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
no mention of plaster walls Pete...
"Construction Techniques - plaster walls"
"DOH"
