I hope someone has found a good solution to how to plug holes in brick. A search for earlier threads turned up nothing.
Client has removed a mantel from brick fireplace, leaving four very visible 1/2″ holes in faces of bricks. How can I patch the holes such that they are not so noticeable? My plug cutter is great for oak, but I don’t think it will work on brick 🙂
Thanks in advance.
BruceT
Fine Homebuilding Recommended Products
Drill Driver/Impact Driver
Whether you're pre-drilling holes or driving screws, this Milwaukee® compact cordless driver is the way to go when it comes to building decks.
Shingle Ripper
This tool makes tearing off shingles easier and faster, providing powerful leverage that allows you to work comfortably. Its beveled teeth and wide blade make it easy to remove nails and push shingles off the roof.
Short Blade Chisel
We always have a wide chisel on my belt for fit and fitting because it’s often faster to grab the chisel rather than going back to the saw.
Guardian Fall Protection Pee Vee
This tool is a gem! You can use it to align plates with your snapped lines, and it’s especially helpful when working alone.
Roofing Gun
This lightweight, pneumatic roofing nailer is capable of driving ¾-in to 1¾-in coil roofing nails and has a depth adjustment wheel to dial in nailing depth on the various shingle types you're likely to encounter.
color matched grout(s)....
WOW!!! What a Ride!
Tile grout like IMERC says just repaired a few dozen holes
in columns left over from tapcons that the carps used to
form up some concrete caps, that I just layed 3 weeks ago
cinnamon red and charcoal is what I used ,turned out darn
good if i say so myself, ar least the HO's wife liked it.
Drill a few holes in a similar brick, collect the brick dust, and mix it in with a little mortar.
