plumber’s test continued……..
Craigabooey | Posted in General Discussion on October 27, 2006 07:18am
11. are slip type traps acceptable on lavatories? Y or N
12. slip type traps must remain accesible. T or F
13. a pressure/temp relief valve is required on a 30 gallon water heater. T or F
14. a water heater or other gas burning appliance should have a flue pipe rise up 1/4 per foot to the chimney. T or F
15. a gas line with only 1 appliance on it does NOT need a gas test. T or F
16. all fittings in the sanitary plumbing system must be GAS tight. T or F
17. compression and flare fittings are acceptable on a copper gas line. T or F
18. A pipe when cut must be reamed and filed to the inside diameter of the bore. T or F
19. Running threads is allowable. T or F
20 Threaded fittings in a DWV system are allowable. T or F
My answers were 11Y, 12T, 13T, 14T, 15F, 16T, 17F, 18T, 19? I put True, 20T
  1. junkhound | Oct 27, 2006 09:02pm | #1
     Since nobody else has replied to 11-20
    16T,      probably false, since only a liquid tight test is required.
    18T,    needs to be reamed but not filed, maybe a trick question?
    19?     I put True, You got that one wrong for sure, running threads wont seal.
    20T,    true here, how else to interface with iron pipe, may be another trick question, as one cannot thread DWV pipe.
    #10, type M - who knows in LI, but it is allowed here.
