Is it a problem if you have a 1″ hot water supply and continue the return loop in 1″ copper as well?
There's a constant source of clean water for you to use, and all you have to do is collect it.
Greetings jeff, As a first time poster Welcome to Breaktime.
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Peach full,
easy feelin'.
You're moving a large volume of hot water continuously (assuming it's not a demand system), and wasting a great deal of heat as well as the electricity required to circulate it.
It's going to cost you a lot for the convenience of "instant" hot water.
Solar & Super-Insulated Healthy Homes
If you are going to use a recirc system, do it wisely. You only need minimal return, not 1". Use 1/4" soft copper, or better yet pex. If you have not bought your circulator yet get a Grundfos with a timer. You don't need hot water 24 hours a day, but you probably use the shower at the same time every day. Anything else turns your domestic hot water into a radiant heat loop.
I run 1.5" circs, but that's for 350 hotel rooms ;-)
1" is too large even for a 7 bath 2 kitchen house.
1/2" is standard, size & fitting availability dictates that. I ran mine in 3/8" soft copper with the smallest Taco pump on the market.
Small pump = low power consumption.
Small diameter pipe = less surface area to radiate heat loss.
“The world is a dangerous place, not because of those who do evil, but because of those who look on and do nothing.” —Albert Einstein
