Plumbing Repair Question
G80104 | Posted in General Discussion on July 24, 2006 12:59pm
  80s era Delta single handle tub/shower faucet with push botton diverter. No water from the shower head! Went to the local Lowes & gota replacement  Delta RP5649 Diverter & the 27/32″ wrench to replace. Ez swap out.
 Fix did little to improve water flow from shower head. Am I missing something? Or should I do like the Pros & just replace the Tub Spout with one of the built in diverters?
  1. Stuart | Jul 24, 2006 01:21am | #1
    Is the shower head plugged up?  They will sometimes get filled up with sediment or calcium deposits.  Try removing the head and checking the flow out of the open pipe.
    IMERC | Jul 24, 2006 01:27am | #2
    pull the shower head and then try...
    good chance of new head or nee to clean the old onr...
    any crud in the aireators in the rest of the house...
    pull the cartridge and run the water.. see if ya get any crud out of it...
    WOW!!! What a Ride!
      G80104 | Jul 24, 2006 03:39am | #3
      Will pull the old shower head & report back!
        G80104 | Jul 25, 2006 05:27am | #4
        Shower head seems fine, think were going to change out the tub spout. With the diverter built in to the spout & see what happens.
  3. FLA Mike | Jul 25, 2006 08:36am | #5
    if that picture is your tub, I don't think you need a shower head
    IMERC | Jul 25, 2006 08:48am | #6
    see if a piece of crud is caught beind the cartridge...
    hows's the flow in the rest of the of house...
    got any fishin' in...
    WOW!!! What a Ride!
      G80104 | Jul 25, 2006 04:14pm | #7
      Will pull the cartridge, flows good in the rest of the house.
      Fishing is OK, few Kings from the boat, 2 days off the Pier, Ocean temperature of 86 degrees....
        IMERC | Jul 25, 2006 04:33pm | #8
        not those two....
        the wimmens...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
          G80104 | Jul 25, 2006 04:43pm | #9
            IMERC | Jul 25, 2006 04:57pm | #10
            that's a start...Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Scaled to Suit the Site
This thoughtfully designed home preserves the character of its neighborhood while maximizing space for a growing family through careful attention to scale, rooflines, and material choices.
  • Sharp-Blade Solution
