I’m replacing some 5/8″ plywood with 1/2″ (roof sheathing) Is there any concern for the transition between sheets— telegraphing thru the shingles?
If so, what is the best way to deal with this?
You might see it telagraphing through the shingles. My first suggestion would be to replace 5/8 with 5/8. If, for what ever reason, you can't or won't do that, use a 1/8 filler against the roof truss before laying down the 1/2" sheating.
Dave
What I got is a fire restoration. The fire dept. cut a 2' square out of the peak to fight the fire. The roof sheathing they cut was 1/2" so I planned and ordered 1/2" ( I ordered 1/2" AdvanTech and didn't get it but that is another rant)
Started tearing off the roof yesterday and found out that I got 5/8" CDX on the majority of the roof- must of used a couple of sheets of 1/2" at the peak.
2 faces of the hip roof will be completly demo'ed so no transitions. On the other 2 faces, I need to replace about 6-8 sheets. All the transition seams will be horiz. I originally thought it wouldn't be a big deal and no one would notice. Since then a few people have questioned me on it and I'm having 2nd thoughts.
Just wanted to throw it out there to see if anyone else had ever encountered a major problem with shadowing. I'm using archy. shingles so I would believe that may hide the transition better then 3 tab.
Shiming the rafter is something I didn't consider, and may be some easy insurance.
#30 felt folded a few times for thickness? From the edge up maybe 1'?
It's only six sheets, so just put 5/8" back. Your 1/2" might measure 7/16" and that would be a 3/16" difference. You might see that. Is it worth it for only 6 sheets? Shimming, for what? Get 5/8" and be done with it.Joe Carola
The good thing about the 1/2" is it is a true .500". I haven't measured the 5/8's" plywood yet where I planned on transitioning it.... but I assume it's 19/32 so the difference should be .100 not a full 1/8".
I all ready have the 1/2" sheets and didn't want to go out today and buy 16 sheets of 5/8". So I was kinda looking for some validation that the transition would be no big difference or easily remedied.
Appreciate the advise even though it's not what I wanted to hear ;-)
"I always wanted to be the last man on earth........... Just to see if all those women were lying to me"
One question I have, Is the framing 16 or 24"oc.? If it is 24 then definitely go with 5/8. 1/2" on 24" centers tends to sag between rafters/trusses, that's the other type of telegraphing that looks like crap. If it was my home , & someone used 1/2 when I have 5/8, I would feel cheated & think very little of you & talk trash about your company. No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
I'm 24" OC for the most part. - Some areas will be 1'OC just because I'm keeping some marginal rafters in place rather then demoing then.
I'm using 1/2" zip roof from Huber (they don't make 5/8" zip roof) no clips, but much more rigidity then 5/8" CDX. Or so they promise.
But your breaking my heart Paul.... I would never cheat on you ;-)
Don't let anybody talk you into something that will make the wife unhappy, cause then you'll be unhappy with only half your stuff.
Okay honey I trust you.LOL
Now you have me learning something new, I havent heard of "Huber zip roof"
sounds interesting.
Let us know how it works.
Paul No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
It looks like 2' centers there and you have h-clips.I thought you also said you had 6 sheets to replace. Either way,what if when you get it inspected and they see that you have 1/2" mixed with 5/8" you run into a problem?Joe Carola
Yep 2' centers & clips. Going back with Zip roof(no clips)
I need to replace 6-8 sheets on each of the 2 "good sides. On the other 2 faces of the hip I'm replacing the whole shooting match.
I'm in a 120mph wind zone but only 20PSF requirement ( We don't get much snow)By prescription I can use 7/16"--- I think we can use 3/8" on 24" centers by code, not that anyone I know would.
Since my crew showed up half in the bag today... we didn't start decking anything.... Just got most of rafters swapped out.....Probably be Tuesday before a final decision will be made on the transition.
Just a side note... My area just adopted the IRC and is going thru some serious growing pains. No inspection on my frame. -renovation permit. But I do have to upgrade the elec. with AFCI's and linked smoke detectors.
Had an inpection last week for my temp. service.... looked like 'Grey's Anatomy' with a bunch of interns following the Dr. around (trainee's)
Begging for something to be wrong it looked like to me... Oh well.
why not just use 5/8"?
If you want to use the 1/2" stuff, I would shim under the edges of it where it abuts the 5/8". You will not see the 1/8" fade to the next truss 2 feet away. If you want to do it right then just get 5/8".
All right everybody quit telling me 1/2" is for hacks ;-)
I agree about 1/2" OSB or CDX (15/32?) Have you ever used Huber's zip roof system? My 1st time also.
I originally planned on 1/2" t&g AdvanTech but you need dispensation from the Pope to get it in my area.
If I do use the 1/2" to swap out the 6-8 sheets per good sides. All the transition seams will be horiz. nothing vertical.--I'll replace a whole coarse, not piece meal.
I plan on spraying 2" of CC foam. But I still may add a radiant barrier so foam may not go straight to the underside of the sheathing-still planning and figuring.
PS. About 30 years ago I decimated the abalone population in your back yard............... Yum fried abalone.
That explains all the fishermen working construction.
It is extremely unlikely that you will notice a difference, visually between 1/2" and 5/8" once it is roofed----especially if using dimensional shingles.
I have pieced in 1/2" pieces in spaces formerly occupied by 3/8" plywood countless times and could never see the 1/8" difference---so why should 1/2 to 5/8 be any different.
stop worrying and get on with it !!!, LOL,
Best wishes, Stephen
