I’m getting ready to take out an existing tub, and I’ve read your suggestions on previous threads… Basically, if it’s porcelain over cast iron, use a sledge. If it’s procelain over steel, use a recipro. So, short of taking the sledge to it and seeing if it cracks, is there any way to tell which it is before I begin?
Don’t worry. I got the tip about using a moving blanket and wearing safety glasses.
Thanks for any help you can give.
Well, if you're ripping it out, you should be able to hang your head over and take a peak. Feel will sometimes tell you. Tapping on it with a knuckle or screwdriver butt end usually sounds deeper on a cast, higher pitched ding on a steel. Once you get it freed up, if you can pull it up and tip it to you, probably steel, if you need to go see the chiropractor, probably cast.
__________________________________________
http://www.quittintime.com/
Sometimes, especially in cheaper steel tubs, you can push a thump into the largest flat surface you can find and feel it oil-can slightly. In cast iron you will break your thumb before it dimples. Stop when you hear the bone crack.
Steel tubs usually have much thinner metal than the cast iron. Is there any "give" in the tub if you stand in it or push on the sides? Try shifting your weight around and see if it moves at all. Cast iron tubs are much thicker and quieter (and heavier), so you should not feel any give even if you really move your weight around. Do you have any indication as to how old your tub is?
uhhhhhhhhhhhhhh....if yer definatly gettin rid of it. Take a sledge and slam it with all your might on the middle edge of the top of the tub. If it cracks/breaks its cast iron. If not...use a saw zall
That was easy wasnt it?
Be anger control : )
NAMASTE
Andy
