are pre fab panels worthy of considering to build a new home in upstate ny where the weather can cause huge delays in the building process?
Do you mean SIP's.
*From the way I read it, I thought you meant Pre-fabricated convential stick-built walls (could you clear this up?)If that's what you meant, it's a pretty good idea anywhere. You just have to make sure your fondation is right on as you won't be able to work things out like when framed on site and can "lose" or "add" a couple of inches if needed.Billy
