Prefinish treads in closed stringer stair
user-2441346 | Posted in General Discussion on October 19, 2014 01:36am
I am building a closed stringer stair.  I am wondering if I should prefinish the threads and risers before gluing and wedging the parts into the stringer.  Does it affect the glue assembly if there is poly in the way?
    deadnuts | Oct 19, 2014 05:01pm | #1
    depends on the glue
    You can pre-finished the exposed faces only w/o adversely affecting your wedged PVA glued joints.  Leave the bottom and back sides unfinished in order to bond your raw wood wedges to the treads and stringer mortises.  If you're planning on using urethane based PL  adhesive, then pre-finishing those components on all sides won't matter much.
    Raw wood guled together with PVA is probably a stronger bond than PL bonded to a film finish coat. However, both would probably serve your boxed stair purposes equally well.
  2. jimmiem | Dec 01, 2014 07:17am | #2
    Prefinish Stair Treads
    In addition to Deadnuts' comments it's a lot easier to prefinish treads and risers before installing.  As deadnuts said, just keep the poly off the backs and bottoms.
