Proper subfloor technique
MisterT | Posted in Construction Techniques on March 4, 2006 07:55am
We all know that any building process has right and wrong ways to accomplish the desired result.
A sturdy subfloor is one of the most fundamental building requirements and one of the least understood.
I have discvered an almost foolproof method of insuring a good, sound subfloor.
this does not rely on any of the “conventional wisdom” of floor construction.
using the right materials is a good start.
as is using them properly.
using adhesive is also very beneficial.
and usig the proper fasteners was an important factor in subfloor performance, before I made this startling discovery.
Usually One type of fastener is best for one type of application.
But a subfloor can require a lot of it’s fasteners so one type is not always best.
to deal with all the stresses and loads that will a subflor will encounter a carpenter must make use of a VARIETY of fasteners.
this will ensure the subfloor will be able to handle whatever is thrown at it or on it.
here is a typical example of a good variety of fasteners:
class dismissed.
Mr. T.
There’s a steering-wheel in me pants and it’s driving me nuts!!!
  1. BillBrennen | Mar 04, 2006 08:33pm | #1
    T,
    Color me clueless here. Is this a joke? What did I miss?
    Bill
    1. MisterT | Mar 04, 2006 08:54pm | #2
      yep it's a joke
      Mr. T.
      There's a steering-wheel in me pants and it's driving me nuts!!!
      1. BillBrennen | Mar 05, 2006 02:03am | #3
        It occurred to me after posting that maybe you found these screws "holding" something you had to demo and were inspired by the absurdity of it all. Am I close?Bill
        1. MisterT | Mar 05, 2006 04:54am | #5
          nailed it Bill!!
          or should I say screwed it???
          Near as I can figger..
          some one took one of late grandpas mayo jars, from the garage where the lid was screwed to the bottom of a shelf, and used it up...
          only flaw with that theory is that there were NO slotted screws!!!
          Mr. T.
    jonblakemore | Mar 05, 2006 03:42am | #4
    T's been working at Paul's house.
    Jon Blakemore
    user-86517 | Mar 05, 2006 08:12am | #6
    Absolutely hilarious! I can't wait for the next class.
    --Andy
    1. MisterT | Mar 05, 2006 02:50pm | #7
      Good to see my humour was not lost....
      thought maybe I was losing my edge...
      Mr. T.
      1. steve | Mar 05, 2006 09:43pm | #8
        thats hilarious!! caught the humour right away!!
        you probably used every driver tip you own to remove that mess
        1. MisterT | Mar 06, 2006 03:35pm | #9
          actually they were all phillips!!!
          My house is a shining example of why people should have to pass a competency exam before they are allowed to buy home improvement materials!!!
          Mr. T.
  4. splat | Mar 06, 2006 06:41pm | #10
    The same is true of carpet.  Sometimes the magic carpets try to get away and try to fly out the window.  Extensive fastening is required upto and including 2" ring shanks.
    I decided to liberate my magic carpets and this is what I found:
    splat
    1. MisterT | Mar 07, 2006 03:02am | #11
      Obviously a hackjob...
      a real craftsman would use piffin screws and fender washers...
      Mr. T.
  • Townhouse Transformation
