Protecting water supply pipe at wall
Do copper water supply pipes need protection from concrete where it passes through the exterior wall? If so, what? This is a retro fit, so I’ll plug the hole with hydro-plug after the pipe is in place. It seems to me that it would be a good idea to wrap the pipe with something.
http://forums.prospero.com/tp-breaktime/messages?msg=44581.3
Thanks! Just what I was looking for.
Can you slide a short piece of pipe insulation down around it?
"Preach the Gospel at all times; if necessary, use words." - St. Francis of Assisi
