Any suggestions for filling the nail holes on exterior PVC trim?
I have used a so-called “putty stick” and exterior caulking before but all they do is statically attract dirt and dust and make every nail hole more obvious.
Anyone used anything with success?
Fypon suggests using DAP fast n easy ( or something like that, by DAP) exterior spackle.
"If you want something you've never had, do something you've never done"
Sphere,
Thanks, I hadn't though (or knew) about that.
Mike
Azek recommends http://www.trimbonder.com
The tube fits a standard caulking gun and costs about $28. It is similar to bond and fill but has a UV protection. Dries in about 5 minutes depending on how deep the hole is.
Cool, thanks! Never heard of that before either.
The product is two part and basically makes pvc when they are mixed. The tips are replaceable and they say if you leave the used tip on, it will keep the product until next time, just put the new tip on and go. It worked fine for a few weeks but after that the remaining hardened up. I only used half the tube.One tip my local Azek rep told me was to fill up any area a little high, then sand it flush. Depending on depth, it is sandable within 30 to 60 minutes. He said it settled a bit when curing. It sands very easily and finishes well.My local Azek rep told me about it last year. If you have trouble finding it, give your rep a call, they'll at least have a distributor.good luck.
Edited 9/9/2007 9:50 pm ET by DDay
Just so you know. Those tubes of 'caulk' that are two parts stink to high heaven. A real nasty chemical smell due to the polyester resins and such. Wear a respirator.
