I am a new homebuilder and using stucco for the 1st time. I plan to sheath the home with O.S.B. (7/16″) and cover the stucco with either tar paper or Tyvek Stucco wrap. Is this an adaquate sheathing technique or should I use something else to prevent moisture damage to the sheathing.
Is OSB ok?
Thanks to whom ever responds,
Ron, Kingwood, Texas
I am a new homebuilder and using stucco for the 1st time. I plan to sheath the home with O.S.B. (7/16") and cover the stucco with either tar paper or Tyvek Stucco wrap. Is this an adaquate sheathing technique or should I use something else to prevent moisture damage to the sheathing.
Is OSB ok?
