Question for sheetrock pros
JohnSr | Posted in Construction Techniques on November 11, 2004 02:53am
My house was damaged in hurricane Ivan and had to replace about half the ceiling in one area.  I removed the pop-corn that was on the old ceiling and want to stipple (sp?) the ceiling.  Can I roll the mud on with a paint roller and then stipple with the brush?  What mud should I use – premix all purpose or what?
I guess I’ll have to experiment with trimming the brush to get the pattern I want – any suggestions?
I am having to do most of repairs myself – all the pros are overloaded, could be a year getting someone to do the work.
  1. calvin | Nov 11, 2004 03:08pm | #1
    There are ceiling brushes of differing shapes.  You can thin down ready mix, dob the pattern on the ceiling with the brush screwed to a pole.  Random is easier than a set pattern.  You can practice, scrape off with a trowel on the ceiling or a scrap of sheetrock.
    Google, but don't just use texture brushes..........you'll get all sorts of computer tools, try plaster texture brush.
    A good commercial drywall supply should have a few to pick from.
    Quittin' Time
    1. JohnSr | Nov 12, 2004 02:27am | #2
      Thanks for the info -  I will find a local drywall supplier
  • Fine Homebuilding's Author Guidelines
