Hey gang, I might have already asked, but it’s been so long, I don’t remember the answer even if I did ask. Acid staining a concrete floor, new construction, and the house has radiant heat. Thought I read somewhere that before putting flooring down, to run the heat for a bit,….something to do with helping to rid the floor of any excess moisture? True? Or am I just losing the marbles that once just rolled freely around the caverns of my mind? Thanks in advance….be gentle. Beck
Re-Home Solutions Inc.
If the crete is 3 weeks or older you are ok to go. I would not use radiant to "dry" out a new slab.
Check out http://acidstain.com for good board on staining.
Good luck
Mike
