Its decision time for our new addition: we’re using radiant heat for the floor (3/4 CDX over engineered joists – full basement)
our choices are either tubing in lightweight concrete or tubing in pre-grooved panels. The contractor quotes are comparable for either system. Any experiences out there with either system?
Either can work fine. More important is to have a contractor that has installed (and made work well) a particular system several times. Call those references!
The concrete will serve as a better "heat fin" and give a little more even floor temps.
If you are doing tile, then go gypcrete. Carpet, linoleum, do either. Hardwood is easier to install onto plywood. Tile or linoleum will offer faster response than the more insulating flooring options of wood or carpet. But any can deliver enough heat if the water temperature is cranked up a bit. -David
Its decision time for our new addition: we're using radiant heat for the floor (3/4 CDX over engineered joists - full basement)
