any suggestions for installation of radiant heated wood floor over a slab? the plan is 2 x 4 sleepers over 6 mil poly, 12″ on center. Then 2 1/2″ of styro insulation, pex somehow?? attached to styro, notched thru sleepers protected by metal plates. Then we’re not sure- do we need a fin system? concrete??
In issue #314, Fine Homebuilding published an article titled “The End of Deep Energy Retrofits” by Rachel White of Byggmeister. The premise was that deep energy retrofits are not as…
any suggestions for installation of radiant heated wood floor over a slab? the plan is 2 x 4 sleepers over 6 mil poly, 12" on center. Then 2 1/2" of styro insulation, pex somehow?? attached to styro, notched thru sleepers protected by metal plates. Then we're not sure- do we need a fin system? concrete??
