The span tables do not seem to agree. Can I span 23’1″ with a rafter tie that is 2×8 or2x10, 2′ o.c. ? With collar ties and a tie from the collar tie down to the center of the rafter tie? 7/12 pitch. 2×4 walls. 2×6 rafters. 10 lb. snow load. No attic or weight on rafter tie (ceiling joist). 5/8″cdx sheething on roof and composition roof. stay focused, thanks for help, Russ
Derpending on th equaltiy grading of the lumber, yes.
#2 would want to be 2x10
Select structural could be 2x8
Your more important consideration is the connection between rafters and rafter ties though. A couple of sixteen pennie nails won't do the job
