Reading material needed; adding beam …
| Posted in General Discussion on January 30, 2001 03:37am
I’m preparing to break through an exterior wall to add an addition. It’s an exterior wall on the first floor of a two story house. Clearly it’s a bearing wall. It bears the second story wall above and the roof. I’ll need to bury the new beam in the wall above, so the ceiling of the existing room and the ceiling of the new room will be in the same plane. The beam will be substantially taller than the joists which will need to hang on the new beam. I realize that substantial temporary support will be needed and that the lower edge of the new beam will rest on the top plates of the adjoining (reinforced) walls, but I’m not sure of how to connect the shortened second floor studs into the beam. What I’m really after is some reading on the subject. Something simiar to what’s in this month’s FHB, but with more focus on opening the wall for an addition rather than for a door. Does anyone know of a past article or a book?
  1. Joseph_Fusco | Jan 30, 2001 04:02am | #1
    Charles,
    This is a very interesting question. I can't wait to read the replies. . .
    © 1999-2000
    "The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it."
    Aristotle
    1. Matt_G. | Jan 30, 2001 04:25am | #2
      *Charles:Sorry, I don't have an answer for you but here's something else to consider:You say that you intend to reinforce the walls that will bear the ends of this new beam. What about the foundation below? You may be creating point loads at the foundation that require reinforcing all the way down to the soil.
      1. Charles_H_Thompson | Jan 30, 2001 04:37am | #3
        *That's an excellent point. It's concrete block, so I think it will be able to carry the load, but your comment points out my need to study up on this before proceeding!
        1. Matt_G. | Jan 30, 2001 04:40am | #4
          *You know it's going to come down to the 'E' word...
          1. Dan-O | Jan 30, 2001 05:01am | #5
            *Hi Charles, Is the addition built yet? The cart may be before the horse. Must those ceilings be co-planer? You may require the services of an architect. Or even a carpenter! We need to to know where your at on this project. Regards, Dan-O
          2. Charles_H_Thompson | Jan 30, 2001 05:14am | #6
            *Nothing started yet. Purely in the planning phase. The ceilings need to be co-planar as the addition will extend the existing room. While searching for a carpenter, I'm trying to get knowledgable enough to ask some intelligent questions. Hard finding someone to take on this kind of work when there's so much more rewarding work available, so I'm also trying to determine if I can take it on myself if I can't find anyone.
          3. Dan-O | Jan 30, 2001 05:26am | #7
            *Charles, A remodeling job is best undertaken with a plan. The work is rewarding. Hire an architect or a builder. Good luck..
          4. Davo_ | Jan 30, 2001 06:28am | #8
            *Charles,Don't want to sound blunt, but you need more than just reading material. What you are proposing to do will take some skill and ingenuity. If you never tackled something like this before ( and from your posting, you have'nt), you would be much better off hiring a carpenter/contractor who has actually done this sort of thing before. Don't risk a building collapse by trying something of this magnetude by yourself.If you have a City or County Engineer or Building Inspector where you live, consult with them about who they would recommend for such a job.Davo.
          5. Jim_Walters | Jan 30, 2001 02:04pm | #9
            *How wide is the opening going to be? It makes a world of difference on just how many upper floor studs are to be affected....Sounds like a lot of extra work and money doing it this way. A header beam would be much easier...maybe a nice set of French doors? Sometimes it's good to design something with the "difficulty" factor thrown in, especially if your doing it yourself. It's always amazed me how well a house holds itself together, but if you remove too much you could cause a collapse. http://www.jjwalters.com
          6. Art_B. | Jan 30, 2001 03:35pm | #10
            *Charles:Don't be put off by those who tell you you're not smart enough to do it. There is a first time for everything. If you have the confidence to try (and yes, to deal with repairing any mistakes) I say try, assuming this is on your own house and your insurance is valid. I built my first house (no insurance) in my early 20's with only books and childhood experiences from parents and it is still standing, but also did experience the "first time" for 150 stitches at once. There are literally hundreds of library books, a good starting point is a simple old classic structural text -- "Elements of Strength of Materials", Timoshenko and Young, Van Nostrand. To paraphrase Matt (#2) -- start at the ground up, even below ground.
  2. Charles_H_Thompson | Jan 30, 2001 03:37pm | #11
    I'm preparing to break through an exterior wall to add an addition. It's an exterior wall on the first floor of a two story house. Clearly it's a bearing wall. It bears the second story wall above and the roof. I'll need to bury the new beam in the wall above, so the ceiling of the existing room and the ceiling of the new room will be in the same plane. The beam will be substantially taller than the joists which will need to hang on the new beam. I realize that substantial temporary support will be needed and that the lower edge of the new beam will rest on the top plates of the adjoining (reinforced) walls, but I'm not sure of how to connect the shortened second floor studs into the beam. What I'm really after is some reading on the subject. Something simiar to what's in this month's FHB, but with more focus on opening the wall for an addition rather than for a door. Does anyone know of a past article or a book?
Fine Homebuilding – July 2023, Issue #316
Find online articles on timber-framed solar canopies; the right footings; the best toilets; choosing insulation; compact cordless routers; and much more.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
