Rebuilding windows
| Posted in General Discussion on December 29, 2003 07:43am
I have read a lot about double hung windows in this forum.  My questions concerns the now defunct Anderson windows.  These were installed when my house was built about 20 years ago.  The only thing wrong with them now is the vinyl (?) slides.  They have cracked and are falling out.  Is there any way to salvage these windows rather than replacing them?  Does somebody make replacement slides that can be installed?  Is there some option other than replacement?
I like the wood because it can be painted.  The new wood (Pella) windows are 2″ shorter or 2″ longer than the windows I have.  And they are $350 bucks.
Thoughts and help would be appreciated.
  1. Piffin | Dec 29, 2003 08:02am | #1
    One of the beautifull things about Andersen is that you can still get parts for any window they ever made. Not alwyaas easy, but doable. I just did some rebuild work on Wood Andersens from 1973
    1. billybobky | Jan 04, 2004 05:01am | #2
      Unfortunately, I have Andersons.  They went out of business.
      1. briank | Jan 04, 2004 06:05am | #6
        Are they Anderson's or Andersen's???  Andersen windows are the very popular brand and I don't think they are out of business---check their website or do a Google search.
        1. Piffin | Jan 04, 2004 06:07am | #7
          I'll take him at his word that they are Anderson's - with an O
          I never heard of them though. Andersen is a great company.
  2. Piffin | Jan 04, 2004 05:20am | #3
    I see.
    If you can handle the prices, Marvin will make inner lining kits any size.
  3. DanH | Jan 04, 2004 05:25am | #4
    If these are fairly standard double-hung windows then you can buy some slides that are intended to retrofit the old sash-cord style wood windows. It might take some creativity to make them fit, but it's worth a try.
    Check with any full service lumber yard (especially one in a neighborhood where lots of older homes are being rehabbed). If they don't carry them they should at least have them in a catalog.
    Dinosaur | Jan 04, 2004 05:52am | #5
    If the sashes are still good, build yourself some new wood cases.  Your local glazier should be able to supply you with new weatherstrip that you can install to the new cases, so they'll be close to the original weathertightness if you're careful.
    Dinosaur
