In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Recement basement walls
dango66 | Posted in Construction Techniques on December 19, 2010 10:20am
Hey Guys,
I have an old home with a stone foundation wall in the basement which needs to be parged.  There are places on the wall where the old cement is still intact.  I have chiseled off all of the loose stuff…
Would anyone have any suggestions as to type of cement mix for this project; portland cement, lyme, sand,   -proportions, ect…?  (Or is is lime?)
Any ideas on prepping/cleaning  the walls?  Afterwards, a bonding agent was suggested prior to cement..
Thanks,
dan
  1. Shacko | Dec 19, 2010 01:23pm | #1
    Re-cement
    Cementing is not my forte, but years ago I did a lot of tuck-pointing on old brick houses, the process was to have a sample of the existing analyzed and then match the composition of the original, this was to be sure the patch would adhere to the original and not crack the bricks or have it fall out.
    The problem with the old masonry work is that the mortar was different from job to job.
    Maybe someone else with more information will post, luck.
  2. TLE | Dec 19, 2010 03:04pm | #2
    Surface bonding cement
    It's been some years since I have done it, but I have used "surface bonding cement" with good results.
    This was a product designed to be troweled over the face of dry stacked blocks to create a structural and water tight foundation wall.
    I did a couple of crawl space foundations with it, but used it mostly as a parge coating for what you are needing and as a coating over Styrofoam on exterior foundations.
    It came as a dry mix bag and contained short fiberglass strands - be careful not to over mix it as the fiberglass strands will breakdown and leave your wall looking "fuzzy". Not a problem for what you are doing but would have a structural effect on dry stack applications.
    Not sure of the contents of the mixture, but my experience was that it was sticky as hell and adhered to a variety of surfaces.
    I purchased it at block supply houses.
    Terry
Decompartmentalizing a 1940s San Francisco Home
This modernized remodel in the Bay Area is characterized by open spaces and an abundance of natural light.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
