Several of my recessed fixtures in my new home do not set flush with the ceiling. I don’t see any way to adjust them. Any ideas?
Hey Dan,
How far beyond flush are they?
*Dan, I have never seen a recessed fixture that wasn't adjustable. There should be 2 or 3 screws in the side of the can that you can loosen to move the can up or down. ( Of course, maybe I haven't seen everything )....these things get cheaper every day, so it wouldn't surprise me too much.
*The ones we use have the frame fixed in placec and the trims just push up into the frame and adjust via a series of snap ridges every eighth inch. The electricians leave them a liitle loose until the painter is done and we just push up until they snap snug against the cieling. With remodeler style cans, there is a snap flange that pops out just above the drywall to engage the back of it and hold the can up. If the hole was cut ragged with a lot of burrs at the top side these could be interferring with this snap flange. Pushing up while rotating can clear it.
Several of my recessed fixtures in my new home do not set flush with the ceiling. I don't see any way to adjust them. Any ideas?
