Refinishing old drywall texturing
dnsykes | Posted in General Discussion on April 3, 2003 06:35am
I know you guys have had to answer this before, but ….
What’s the best way to remove a heavy texture from drywall? I have an old house that needs a lot of sheetrock and texturing work. I’d like to remove the old heavy texture and replace it with a more up to date “knock-down”. I’m I simply facing sanding/grinding?
Thanks,
  1. andybuildz | Apr 03, 2003 07:53pm | #1
    or scraping if yer lucky.....or rerocking over the existing with 1/4" rock.
    Be a dust mask
                       Namaste
                                       andy
    "Understanding yourself is like trying to bite your own teeth"
    Alan Watts
    coonass | Apr 04, 2003 12:08am | #2
    dave,
    Why not remud? Roll on a wet base and wipe off with a 2' trowel. Do it twice and you'll have a slick finish. Plus your arms will get big from the 2'er.
    KK
    1. dnsykes | Apr 04, 2003 04:42pm | #3
      That's probably the best idea. This is one of those situations where you know what you have to do, but you're just hoping that someone has a miracle cure that they've developed since the last time you faced this situation.
      Thanks.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
