We have been getting little specks of green mold in our ice cubes, produced from our refrigerators ice making machine. I read somewhere that the water supply line to the ice maker / water should have a secondary filter installed?????
How can I tell if there is one. Where do they usually locate/install them? At copper feed line entry point to back of refrigerator? somewhere in copper flex line? If it appears there is no filter for the water supply line for the ice maker, what is the procedure for installing one? level of difficulty?
Chipper 5/30/2004
Barrel looking gizmo in the water line sats filter on it... Usally white...
If you got one... Change it....
Plan "B" check the owners manual and seee if you have one built into the system...
New install is cake and pie... Buy an inline cartrige and it come with all the hardware and instructions... Look for a 2 or 3 micron carbon / phosphate... 1st tray or 2 of cubes will look freckeled unless you run a little water thru it before final hook up..
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming....
WOW!!! What a Ride!
Is the mold inside the ice cubes or on the surface? If it is inside, the source is the water. However, if it is on the surface, it is likely growing after the ice has been made. That is, it didn't come in with the water, but came from inside your fridge.
ummm..I don't think mold can grow at 2 degrees above zero.
most freezers are at -180
Got a Brandy new maytag...2 degrees up or down from zero..on the third from lowest setting..180 below is ludicrous.
Maybe the kind that Ted Williams is stored in........but not the kind that my chicken pot pie is in.
ROFLMAO..at home cryogenics, don't bury uncle bob, freeze him! I can just hear the sales pitch..
"Now you too can have your very own,personal cryogenic freezer! Just imagine what you can do with this baby, why you can take that ailing relative that has been living with you for the last ten yrs. and just refuses to die..and, freeze them until the miracles of science find a cure..
Ok we know technically they still live in your house, so you will not lose that dependant deduction on your taxes! Why, just that deduction will make the 'Home cryogenic 2004' PAY FOR ITSELF..in just a few short years!
So act now (our operators are waiting) and we include our newest cryo -bags to avoid that unsightly freezer burn..AND If you call in the next ten minutes and use your major credit card we will include a second PET SIZE Cryo-2004...perfect for cats, dogs, and up to 25 gerbils! YES that;s right 25 Gerbils..won't little Trixie be glad? Never dig another hole, never send another gerbil on the big SURF..and it is INCLUDED ABSOLUTLY FREE!!! So act now..call..send your entire wallet!"
BUT WAIT!!! There's more...
One little typo and........
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming.... WOW!!! What a Ride!
"We'll include the MICRO 2004..extra heavyduty defrost-o-matic!
Yes, we willhave your loved ones defrosted in just seconds, not hours, not minutes...just seconds. It even doubles as a clothes dryer! Never put another dollar in the dryer again!..Think of the savings!..
Isn't freezer burn more or less like sun burn? Just smear a little aloe vera on, good as new. As always, thaw slowly in the frig so that the out parts don't rot before the middle is thawed. It'd be such a shame to thaw out granny after 30 years only to have her die of gangrene a few days later.You're unique! Just like everyone else! Scott Adams
Oh no! You're not going to turn this thread political, are you? ; )You're unique! Just like everyone else! Scott Adams
More likely the zero was supposed to be a degree symbol or a capital C. -18C is 0F.
Thanks for posting the likely and reasonable explanation.You're unique! Just like everyone else! Scott Adams
-180? You certainly have got my interest. Where did you come by that information?
Hey, you could make dry ice at home!You're unique! Just like everyone else! Scott Adams
Careful you on't bang the hand you reached into that freezer with...
Or just keep a dust broom and pan handy...
the mold is inside the ice cubes
You should not need a special filter for an ice maker. It's the same water you drink and bathe with all over the house. If there was unsanitary stuff in the water you'd have a bigger problem on your hands.
It could be that your icemaker mechanism needs to be cleaned and sanitized. I've never seen it necessary on a home unit, but on larger units, like in hotels, there is a little heater which melts the cubes just enough for them to pop out. Sometimes this is enough heat for mold to grow on the trays or mechanism. Scrubbing with water with a little dish soap and just a little chlorine bleach will clean it. Rinse well.
The other possibility is that it's bits of copper corrosion from your plumbing. A filter would take it out, but it would be better to eliminate the corrosion in the first place.
When you melt the cubes, are the little green things hard or soft? Corrosion would be hard.
