Remodel Sequence
pete123 | Posted in General Discussion on October 18, 2009 08:44am
Having gutted the daylight basement level of our house…it has been sheetrocked, textured and painted towards finishing the remodel. Floors are plywood underlayment. Bathroom and laundry room are tiled but bath toilet and sink not yet installed. Intent is to carpet the whole floor and trim out everything…install doors in rough openings, cove base, window trim etc. My question is what is the best sequence of finishing the remaining tasks. Any comments are much appreciated…
  1. Marson | Oct 18, 2009 08:56pm | #1
    Carpet goes in very last. Leave base trim and doors up 3/8 or so. (assuming a stretched carpet with pad). tile the floor in the bath before trimming out that room however.
  2. calvin | Oct 18, 2009 09:09pm | #2
    I would set the doors, trim it out, set the fixtures and then carpet.
    Any trim that needed to wait for the carpet (?) could be done later.
    http://www.quittintime.com/
    1. pete123 | Oct 19, 2009 08:10am | #3
      So the carpet would typically tuck under the cove?
      1. calvin | Oct 19, 2009 01:57pm | #5
        Rubber cove base would go in after the carpet.
        I'm thinking now you are perhaps using glue down carpet?  In that case I would change my tune and set doors and casing after carpet.  Then install the rubber cove.
        If doors were set b/4, not the end of the world.A Great Place for Information, Comraderie, and a Sucker Punch.
    Dinosaur | Oct 19, 2009 08:43am | #4
    Carpet after everything but the base, plinthe blocks, and casings. If you prefer, you could set the casings first, to a calculated height, then cut the plinthe blocks to the exact height needed to squash down into the carpet once it's installed.
    Design for a plinthe block at least a half inch taller than the base, so if you guess wrong by an eighth in the carpet height it won't show.
    Dinosaur
    foolish men call Justice....
