What is the best way to remove a double cylinder lock that is attached with screws where the screwdriver will only engage the screw heads turning clockwise? Is my only option to drill out the screws? Thanks.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
Take a Dremel tool with a thin abrasive cutoff wheel and cut regular screw slots into screw head. Or just cut inot the curved shoulder enough to square it up for a regular screwdriver.
Probably too late......................................BUT
Center punch and drill the heads off......two lock halves should pull apart.
I have better luck with holding a drill on target than a Dremel.
..............................Iron Helix
44 auto magnum. Takes out deadbolts real quick. Just ask Clint.
