In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
removing old grout
stnfly | Posted in Construction Techniques on March 28, 2010 07:10am
any  thoughts  on the  quickest  way  to remove old grout  with out removing tile to regrout
  1. DanH | Mar 28, 2010 07:31pm | #1
    Darn, you had to add that last qualification, didn't you??
    The standard approach is a "grout saw" -- a sort of oversized toothbrush handle with a bit of saw blade attached instead of the bristles.  Readily available at a Big Box or tile store.
    Quicker is either a Dremel with a large abrasive wheel or (better) a Multimaster (or clone) with an abrasive blade (though these options don't work well on narrow grout lines).  For really wide grout lines you can even get away with a regular circular saw with an abrasive blade.
    Of these options, only the manual grout saw works very well on caulk, if you have some of that to remove.
    If you're only replacing the grout due to staining, note that you only have to remove maybe 1/16" of grout (maybe 3/32" for sanded grout) in order to make enough of a depression to regrout.  (For this duty sometimes the Dremel with something resembling dental drill will work.)
    But note that if you're removing the grout because it's cracked there's a good chance that the reason for that is that the tile backer has gone punk and to the whole thing needs to be torn out and redone anyway.
  2. Clewless1 | Mar 29, 2010 08:04am | #2
    What Dan said ... yeah it's a lot of work sometimes, but may be the only practical option. As with many things you try the various available known techniques and then begin to discover what works best for you ... and then add some of your own variations.
    Are you doing a large area or just a few grout lines?
Adaptive Rainscreen Siding Clips
This fastening system from Nova USA Wood Products accommodates natural wood siding expansion and contraction.
  • Podcast 460: PRO TALK With Builder Keith Bohling
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
