In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Removing PL from pre finished hardwood
Blaeberry | Posted in Construction Techniques on March 28, 2010 03:39am
A friend needs to remove some PL from prefinished hardwood flooring.  Any suggestions?
Thanks.
  1. calvin | Mar 28, 2010 09:50pm | #1
    PL? the Premium Urethane adhesive?
    I would call the company and as if there's a way w/o removing the finish.
    or
    I would take the sharpest chisel or scraper sized according to the adhesive. and attempt to remove it and not dig into the wood.
    if PL is something else-disregard.
    1. Blaeberry | Mar 29, 2010 09:44pm | #3
      Yes, by PL I meant the polyurethane adhesive.  Not sure exactly which PL it is.  Do you know what solvent would work on PL?  Whether it would be safe for the floor finish would need to be ascertained, probably from the manufacturer of the flooring.
      Thanks for you response.
      1. calvin | Mar 29, 2010 10:11pm | #5
        Thinner and denatured alcohol
        work for mild cleanup when fresh, but..........when cured?  oh boy.
        Remember the black that stays for a week on your hands and then only leaves after a good rib dinner?
        That's it, some juicy bar-b-q maybe.
        Definitely contact the manufacturer.
        1. DanH | Mar 30, 2010 08:06am | #6
          In some cases saturating glue with furniture oil or some such will cause it to give up it's hold on the surface.  Doesn't dissolve it, but works into the joint and breaks the ionic bonding between materials.  (Only works on fairly smooth surfaces.)  May take days of applying, waiting, scraping, thouigh.
  2. DanH | Mar 28, 2010 10:05pm | #2
    First thing to try is a DULL scraper, to see if the finish is sufficiently smooth and chemical-resistant to "shrug off" the PL and allow it to be scraped off.
    1. Blaeberry | Mar 29, 2010 09:47pm | #4
      Dull scraper
      Sounds v. sensible to me.  A drywall knife with a few miles on it would be a good bet.  She has these.
      1. sisyphus | Mar 30, 2010 10:56pm | #7
        Lee Valley sells plastic "razor blades" of various types.
    2. sisyphus | Mar 30, 2010 11:00pm | #8
      Would trying to freeze it with dry ice or something like that  be worth trying?
  3. JTC1 | Mar 31, 2010 09:26am | #9
    Bond breaking
    I have not tried this on pre-finished hardwood and would experiment on flooring scraps.
    Like DanH said - repeated oil soakings attempting to "work under" the PL and break the bond.
    Additional compounds to try - WD-40, Liquid Wrench, 3-in-1 oil, hand lotion, waterless hand cleaner, olive oil, mayonnaise.
    For scrapers I would use one of the "disposable" plastic putty knives - tend to provide a reasonable amount of scraping force without marring / scratching finishes. I like the white plastic ones the best.
    Jim
Designer Kitchen Cabinets on a Budget
This Danish manufacturer has found a way to bring modern, architect-designed cabinetry to the masses.
  • Cordless Drywall Cut-Out Saw
  • Podcast 461: Adding a Screened Porch, Insulating a Raised Addition, and Preventing Termites in Exterior Foam
  • Decompartmentalizing a 1940s San Francisco Home
  • Upgrade Your Window Air Conditioner
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Tool Guide 2022
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
