While doing some minor fixup work, I was given an 18″ x 30″ piece of 3/8″ thick glass. I want to add it to a coffee table but it has a few scratches, nothing real deep, but I was wondering if anyone has removed scratches from glass, and how did you do it?
(I’ll post on FWW also)
You may want to talk to a local glass & mirror shop in your area, they must have some magic for that.
No one should regard themselve as "God's gift to man." But rather a mere man whos gifts are from God.
A glass shop may be able to buff it out, but it may cost as much as a new one to do, depending...
cerium oxide
Thanks. That product appears to be the way to go.
if a coffee table, shouldn't you use tempered glass?
Maybe so...but it is going to be setting down into the top and there will be a piece of wood (ply most likely) underneath it. It can be broken but it shouldn't get shards of glass around.
I have a square lamp table done this same way and it has survived for 12+ years, but I know it could get shattered tomorrow.
Harris To prevent shattering newly cut glass, try chamfering the sharp edges on all eight edges Hold the piece of glass under water (in a plastic tub)and with a wet brick, or,piece of an old grind wheel, rub the edges to take off the sharp edges It would take a heavy hammer to shatter 3/8" plate glass. Steinmetz.
I have a 2' x 4' x 1" coffee table that's about 50 years old - has some scratches & a couple og good-sized chips out of one corner - I consider it patina, & like it better than something that looks brand new...
Embrace patina!
Edited 6/5/2007 5:27 pm ET by kate
toothpaste
A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do...
I've gotten some excellent advice and learned some new tricks. I think Kate has the best advice..."Embrace patina!" Cheapest too. And I think that the glass is thick enough to withstand a few more years. Wish I knew what it had been in its former life.
john
Flip it over. The scratches will be on the bottom.
And if that doesnt work, just use a hammer.
I removed the smallest scratches using wet/dry sandpaper, and cleaned up the edges of the deepest scratches w/same. I polished it with some ceramic polish and it looks marvelous. I am going to polish the edges of the deep scratches some more today using toothpaste and that will be that. I think the ceramic polish was cerium oxide...it came from a friend and she just called it ceramic polish.
