I am trying to remove some 20 year old sheet vinyl flooring which I plan to replace with new vinyl. Since it was curling up in places and appeared to be easy to pull up, I assumed it would all come up easily. In many areas just the top surface of the vinyl comes up leaving the bottom surface still glued to the plywood floor. I have a pretty heavy duty floor scraper that I have been using with some success, however there are still a lot of areas that won’t budge. Am I going to have to sand the floor or is there some kind of solvent that might loosen the remains? I have already considered burning down the house, but I am afraid that is just wishful thinking.
Water is a great solvent for losening sheet vinyl. But you would have to flood the floor. Scraping and cursing is how I always did it.
Try some detergent in the water to help it "wet" better.
Rent an electric floor scraper. Has a sharp oscillating blade that will remove all residue. Fast too.
There is such a thing as adhesive solvent that will help to cut down on the scraping and swearing, although some effort is still involved. Thank you for reminding me I will be needing some on Wednesday. Have fun, and concentrate on how nice it will look when you are done
Dan
paint thinner...
safer..
Since new vinyl will telegraph imperfections in the underlay I'll usually overlay the whole thing (without tearing up the vinyl) or cut the old underlay/vinyl into manageable pcs and tear it all out.
Maybe, lay wet towells over the problem pcs of vinyl for a while and then use the scraper.
Quittin' Time
Thanks for all your suggesttions. I tried the soapy water method first without much luck. Then I rented the power scraper from HD. That did a pretty decent job on the top layer of the vinyl but did not make much of a dent in the lower. I took it back to HD and then rented a rectagular floor sander. It took several hours but at least it finally got all the paper off. I guess if I had to do it again I would have just covered the old stuff with a layer of underlayment. That probably would have been the least painful way to go - other than burning down the house! Thanks all of you for all your help.
I just had that same situation and the entire floor had the lower surface of the vinyl that stayed on the floor.
What worked for me was to use a 3 1/4" powered planer (Bosch) over the entire floor.
Sounds like a lot of work, and it was - but it was the quickest way to get the floor down to subfloor bare wood.
This was a kitchen that I just finished and I installed 3/4" hardwood flooring in.
I used the planer hooked up to my Fein vac the entire time - no dust.
Good luck,
Julian
That does sound like a lot of work. Happily, this job is now behind me. Thanks for responding.
