For some strange reason, in my garage the previous owner put down a section of vinyl flooring about 2-3 ft. wide and about 12 ft. long. I would like to put down some type of concrete finish (stain or epoxy) and would like to know the best way to remove the vinyl. So far I’ve just chiseled it up but I’m hoping there is a better way and also some way to deal with the glue residue. Thanks for any suggestions.
You're in luck. Soak it in water. If you can peel off the top vinyl layer, the water will be able to get to the adhesive easier.
Then after all the cardboard backing and adhesive has been removed, you will have a smooth floor that won't take an even stain. The adhesive will have sealed and contaminated the concrete.
I can loan you my Labrador retriever. Just start an edge, she'll take care of the rest.
You can rent an electric machine that will make quick work of that task.
TRIGGER
Home Depot in Livonia, MI is selling their rental sm. floor scraper. Reg. $1200, they are selling one for $300.Cool unit - can use it with a trigger handle or in your hand. has a 9" blade.I'm such a tool junkie - I was close to buying it - there's been 5-6 times when it would have saved a lot of time on a job.Problem is - most new floors these days are laminate flooring, and they go right over the old floor...JT
