repair barn foot cracked & tilted??
Are there other options other than completely replacing this footing?
The overall barn is about 35 long by 25 wide.
According to my RoboLaser, I’m 3-4 inches lower on this side from the bottom of the upper floor joists. “This side” being the long side of the retangle.
Thanks for any input.
Make an opening or enlarge the one that already exists.
How do I build a wall on that?
Well it would be a good idea to start by supporting the wall above, Take a couple staging planks and prop them under the over hang in several different spotsmaking sure that they are wedged in good( tack some nails in them ) to carry the weight above. Then decide what you want to do , how far do you want to get into it. You can rent a jack hammer and take out whats there then build a form and pour some new cement with anchor bolts .It`s all up to what your comfortable with other wise bring in a contractor to do it for you. And you will need to address the drainage problem while your there also.
Edited 3/19/2006 3:01 pm ET by Shavey
1st thing I did was to put supports up :)
Have you made any progress on your repair yet.....
It's just a barn, isn't it?
I'd deal with the rooten wood and leave the thing alone.
You ain't buildin' a piano.
Thanks. Yep, just an old barn, but I got to replace the whole wall due to rot about 20 feet. So with a cracked footing I don't know how to put a bottom plate down
go with a heavy beam - 3-2X6 or 2X8 secured together or so - float across the cracked section using a mortar mix - tapcon or lag/expanding lead anchor, let set for a day and then rebuild wall to something resembling level/plumb -
there are drainage issues or the foundation wouldn't have moved like that -
"there's enough for everyone"
that sounds like a good idea. I'll look into it.
Depending on the value / use of the barn, mud jacking could be a solution. Basically pumping grout under pressure under the low area. Stabilizes the soil and raises the foundation.
Drainage is certainly a prime suspect as the cause for the settling. Poorly compacted soil could also be the cause. Obviously, gotta find the cause first.
think it poor soil; too soft
Heck, in a barn you want it sloping to improve the drainage. So long as the building's upright, what the hey?
happy?
