repairing drywall vertical hair cracks
danz857 | Posted in Construction Techniques on August 18, 2006 05:53am
Is it okay to repair vertical drywall cracks (inside corners)  to with caulk, drywall contractor says this standard practice.
Dan
  1. DanH | Aug 18, 2006 06:11pm | #1
    Sometimes that the best option, sometimes it's a hack. Depends.
    IMERC | Aug 18, 2006 06:23pm | #2
    why did it crack....
    standard practice ya say....
    all that means it's the "cheapest" way out... and leans more to a hack repair...
    WOW!!! What a Ride!
  3. DonCanDo | Aug 18, 2006 07:57pm | #3
    I'll often "fix" hairline cracks in drywall with caulk.  Especially the ones that grow and shrink seasonally.  Joint tape will not keep the house from moving.  Of course, I tell the customer what I'm doing and that it's not a permanent repair.
    However, hairline cracks on inside corners are rare because the joint tape usually pulls away before cracking.  I even saw a corner once where one wall had dropped 1/2" and puckered the joint tape along the whole corner without cracking.
    Check to make sure that there's joint tape in the corner.  Check for any movement.  It's possible that there's a missing nailer.  If you re-tape (which is probably what's needed), prime the area first to give the joint compound a better grip.
    -Don
  4. Mooney | Aug 18, 2006 10:26pm | #4
    yes
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
