Re: FHB176-Replacing a Shower Mixing Valve. Don’t you need to install air chambers above the water supply lines? I am bidding on a project where the customer wishes to save the “mud-set” tile and replace the existing two handle valves. However, I was told that all the interior walls are concrete block with a skim coat of plaster. Is it possible that the plumbing wall would be packed solid? The 7 story high rise building was built in the early 1950’s and is located in Evanston, IL. I have yet to open the wall.
Greetings xh,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someones attention that can help you with advice.
Cheers
'Nemo me impune lacesset'
Did you send an attachment?--couldn't open.
No, I was just bumping your post to the front of the discussion listing again to increase it's exposure.
No attachment was included. It is just a service to the forum as a way to repay my educational expenses.
'Nemo me impune lacesset'No one will provoke me with impunity
How'd you get Piffins signature line?
Seemed proper for the copy/paste procedure of the puter.
Once something has already been posted anywhere on the Taunton's boards, as example a photo, all that is needed is a copy/paste to place it on a post here, without the need of an attachment.
Air chambers are not need except by solenoid type valves, ie a dishwasher or a washing machine.
Actually in michigan "air chambers" are no longer allowed. You have to use the fluid filled (or mechanical) Arrestors.
Some places air chambers are legal But I don't recommend them . They fill with water in 28 days.
Mechanical hammer arrestors are preferred but in some locals the code requires access to them .
Like someone already posted they are not needed on shower valves.
