Replacing tile backsplash
| Posted in Construction Techniques on April 11, 2004 02:50am
Re-hash…Need to remove 12″ tiles on a sheetrock backsplash in the kitchen and install new tiles.  I know the SR ig going to get torn up, at least the paper will peel off.  Thinking about laminating a layer of 1/4″ hardie over the remaining SR and going from there.  Or am I better off cutting off the remaining SR and replacing it?  The tile will go corner to corner, and counter to upper cabs, so thickness is not an issue.  And if I replace the SR, should I add a layer of Hardie anyway?
Whenever you are asked if you can do a job, tell’em “Certainly, I can!”  Then get busy and find out how to do it.  T. Roosevelt
  1. crosscutter1 | Apr 11, 2004 04:26am | #1
    just cut the rock out & replace the rock with the same thickness drywall . there is no need to put dura rock on it because its not being walked on .
    pop the bottom & upper tiles cut the rock with a sawzall being carefull not to go to deep !!when i do this i usally have my helper hold the end of a shop vac as i cut so the dust doesnt go allover ,open a window & put a small fan in there also if you can
    1. FastEddie1 | Apr 11, 2004 05:06am | #2
      Clear enuff...cept there's no top & bottom tiles...see attached.
      Whenever you are asked if you can do a job, tell'em "Certainly, I can!"  Then get busy and find out how to do it.  T. Roosevelt
  2. HeavyDuty | Apr 11, 2004 05:33am | #3
    Have you considered tiling over the existing tiles? No dust no mess.
    I know deep down most of us don't like leaving anything that we want to replace under new work, but sometimes it may just make sense.
    1. FastEddie1 | Apr 11, 2004 05:37am | #4
      No Tom, that thought had not even occured to me.  Not sure I like the idea.
