In a few weeks I will be tearing off 12″ hardboard siding and replacing it with 8 1/4 Certain teed fiber cement siding. ( yes I know working with this siding will be difficult). I will be tearing off the siding and fiber board underneath down to the studs and covering the walls with OSB.My questions are: #1. Is 7/16 OSB adequate for 24″ stud spacing on a wall or go with a thicker OSB ? # 2. 15# felt or Tyvek under the siding? (I don’t mind paying for Tyvek but for a remodel is it worth it as it would be more difficult to use) #3 For the vertical trim on the corners of the house is preprimed 3/4″ x 4″ finger jointed redwood good to use here? #4 Any suggestions for a brand/type of air nailer for the siding? Thanks for any help.
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
if you're going to blind nail.. you can use almost any gun you like...
if you will face nail.. i like any siding gun that will shoot a SS. nail...
In a few weeks I will be tearing off 12" hardboard siding and replacing it with 8 1/4 Certain teed fiber cement siding. ( yes I know working with this siding will be difficult). I will be tearing off the siding and fiber board underneath down to the studs and covering the walls with OSB.My questions are: #1. Is 7/16 OSB adequate for 24" stud spacing on a wall or go with a thicker OSB ? # 2. 15# felt or Tyvek under the siding? (I don't mind paying for Tyvek but for a remodel is it worth it as it would be more difficult to use) #3 For the vertical trim on the corners of the house is preprimed 3/4" x 4" finger jointed redwood good to use here? #4 Any suggestions for a brand/type of air nailer for the siding? Thanks for any help.
