Restoring Antique Oak Dining Room Table – Finish Coat
dauby | Posted in General Discussion on April 25, 2013 10:06am
I have an antique solid oak dining room table (around 1900).  I have used denatured alcohol on it and most recently Formby’s Refinisher on it.  I am confused as to what to put on the top as a finishing protective coat.  I want to protect it while preserving its antique nature.  I was considering tung oil or linseed oil but after reading differing opinions I am not sure either would give the table a durable enough finish.  Plus – the differing opinions were very confusing.  I am not opposed to using either of those finishes but just not sure what to put on it. The table has a beautiful even look now. This table will be used on a daily basis but will not have rough use.  Thank you for any input.
  1. rdesigns | Apr 25, 2013 03:04pm | #1
    Even though Tung oil, Danish oil or other oils will not leave a built-up film  like varnish, polyutethene or lacquer, they are reasonbly protective for a dining table that sees daily use.
    They will seal the wood from spills and will give the look you want, not a plastic gloss like other topcoats.
    Also, they are easy to repair or to give additional coats over the years without the need to strip down.
    MarkH | Apr 25, 2013 07:04pm | #2
    Well, shellac might be a good choice too.  Look up french polish foir ideas.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
