Has anyone had an opportunity to use the new patinated copper from Revere that they brand Freedom Gray?
It works like plain copper but soldering it is a bear.They want you to use lead free solder with a flux with high tin content.They also don’t want you to use flame to solder,even locked seam 20 oz. seams,but rather 3 to 5 lb. hand coppers.
Anyone had any experiences or suggestions ,their tech rep was out on Friday,but I’d like to hear about any real world knowledge if someone can help.
Thanks,from a newbie to this site.
Walter
They want you to use lead free solder with a flux with high tin content.They also don't want you to use flame to solder,even locked seam 20 oz. seams,but rather 3 to 5 lb. hand coppers.
First, I quit using terne metal when they switched to Terne II because it was so hard to solder. If I remember correctly, Freedom Gray is a similar coating to Terne II.
Secondly, I would never use an open flame to solder locked seams. I've seen two historic buildings burnt down by roofers using open flame to solder. Get some 5 lb coppers. Good luck.
You're almost as paranoid as the people that're trying to kill me.
