Anybody make a RF remote unit to put in a wall box to control a light? I don’t mean having a switch box unit. I need to control two wall-mounted scones independently. They will flank a bed, and each unit needs it’s own control, so the frequences need to be different.
Your question is not clear. Do you want a control to that will go into a switch box, a receiver module that will go into a lighting fixture box or both?
And why does it have to be RF?
http://www.smarthome.com/2536t4wh.html
http://www.smarthome.com/2536r3.html
These two might do what you want.
There are also X-10 only solutions. And RF to X-10.
And if the garge door opener is Home-Link compababile (which most are) you can also control the lights with extra buttons on the GDO remotes.
Start here.
http://www.smarthome.com/prodindex.asp?catid=1
And BTW, the use of different frequencies for different controls went out with Marconi. They use different codes.
Thanks for the info. It's just a RF reciever similar to a RC ceiling fan control.
Marconi? I like it with cheese.... ;-)
Yeah, you probably want something in the X-10 stable. It's not real sophisticated, but fine for your needs. Lots of different options available.
