Ridgid in + fiber glass batts in walls
alfie | Posted in Energy, Heating & Insulation on November 23, 2008 04:16am
I am building a house in Connecticut, 2×6 framing. I am applying 1†rigid insulation on the outside, to the exterior of OSB sheathing. My intent was to spray foam insulate the cavity from the inside.
An insulation sub has suggested that having achieved air sealing with rigid insulation outside, I should simply go with fiber glass insulation batts on the inside. The combination of the two insulations would give me air sealing and a good R value. He feels this is a cost effective solution.
Comments?
  1. DickRussell | Nov 23, 2008 06:31pm | #1
    My first thought is how one concludes that adequate air sealing is obtained simply by using 1" rigid outside. You have to consider all possible paths for outside air into the cavity, such as between sheathing and rim board and all other wood-wood connections, plus wiring holes. If flexible sealant has been used liberally at the wood-wood joints, and foam at wiring holes, and all those other good things done to really, really seal up the cavity at both interior and exterior, then you still are only halfway there.
    Consider all that has been said on this forum and elsewhere about FG batts being a low-end insulation. One might argue that a high-density FG batt, if totally sealed against air infiltration, can provide the stated R value, and some still will argue about thermal loops induced by high temperature differences. So maybe, maybe not.
    The one argument against FG batts that is hard to counter is that getting the stuff really installed well, fitted very carefully into corners and around wiring, is rather elusive. Unless you are doing it yourself, and taking the time to do an excellent job of it, FG batts still come up being the low-performing, low-end insulation.
    You've gone to the trouble of having the foam on the outside, trying to get a good result thermally. Why screw it up now with a low-end insulation to finish up? There are better cavity fills out there.
    1. alfie | Nov 23, 2008 08:59pm | #2
      Thanks - all very helpful thoughts.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
