I will soon be installing a sewage pump in my home. The pump manufacture (e-one) specifies 1 1/4″ pvc that is rated for at least 200 pounds of pressure for the discharge pipe. I purchased today schedule 40 1 1/4” pvc that is labeled as 370 pounds, but is also labeled “cold water only” and the invoice even said ” for water lines only”.
So I am confused to say the least. seems like it should work just fine and I won’t be pushing my luck at all, but I sure don’t want to have a problem with a sewage pipe under pressure.
What would you do?
The last three sewage ejectors I did were plumbed with ABS
Have a good day
Cliffy
No problem with the pipe you have.
They have that on the pipe so people won't run hot water in it , the pressure rating drops when the water gets hotter.
Every foot of lift is roughly equal to a half pound of pressure, so what ever your pump says it will lift divide that by two & that will be the maximum pressure your pump will do at the base.
When asked why is there four engines on a 747------ "cause we couldn't fit six" a Boeing engineer
Oh & one othe thing
The "cold water only" also means do not use the pipe for your shops air compressor, unless you like PVC frag grenades.
Thought it was allright, just wanted to hear the same from some one with lots more on the job training.
thanks again
