Hi All,
I have a small job tomorrow that has me not able to drag a TSaw along.
What’s the best way you’ve come up with to make an accurate, clean rip of a 1×3 to 2 1/2″ wide???
My solution: Buy the lumber and take it home to my shop and do it.
Or. Rip it rough with a skilsaws and plan it down to dimention.
Is there a better way?
Cor.
You do know that a 1 x 3 is already 2 1/2" wide?
I occationally use my skillsaw screwed to the bottom of a piece of 3/4 plywood. Setting up the tablesaw is too much of a pain for ripping one or two pieces on a baseboard job.
Drill 4 holes on the baseplate of your skillsaw to mount on plywood.
Plunge through plywood to the proper depth
Use a piece of wire to fasten the trigger. (UNPLUGGED)
I use a switched powerbar for the on/ off. but you can plug /unplug in a pinch.
Flip it over onto a couple of sawhorses, and fasten so it won't slide off. (you'd be suprised...)
A chunk of board screwed to the top will suffice as a fence.
(Don't let the toolhounds see you ;~)
Enjoy.
Gord
St.Margaret's Bay NS
When I'm working without a tablesaw and want a clean edge, this is what I do:
First, I make the rough cut with a circular saw or jig saw. Then, I secure the piece and plane it to exact dimension with a power planer. Securing the board is the hard part, but it's done quite effectively if you use one of those wood-jawed "woodworkers" clamps. I tighten the wood in this clamp, and then secure the first clamp to a table top with a conventional clamp. It might sound confusing, but hopefully you get the idea.
This method works pretty well, especially if you need a tapered piece.
i'm not sure i can explan this method but here goes.take a pair or stair gauges [ the little brass pcs that go on a square to set stairs].attach one to the front and back of your skillsaw base at the distance you need from the blade so that you have a guide at the front and back of your base. works pretty good up to about a 3" cut. larry
Sharp blade & a rip guide on the saw does wonders!
Yep,
If it's not worth dragging the table saw out, or it's too small for the shoot board, I go back to the truck for the rip fence. FWIW, you can do some pretty decent work, even on small stock with a shoot board if you get creative enough.
I had a welding shop make me a 2ft rip gauge years ago,simply welded a couple together. Comes in handy when ripping ply to fill TJI webs.
I didn't do it....the buck does NOT stop here.
I can get pretty darn good results using my finger as the rip guide,on rips less than 5" or so.
If you don't have a rip fence you can sometimes improvise with a couple of small clamps and a piece of 1x.But I figured someone would chime in here about that guide system everyone's been hyping.
Secure the filler
with Clamps
Cut right on
the line
Tapered cut
You can allways make something like that. Then you can do all your jobsite cuts.
Better-fester-easier and SAFER than your table saw.And the jobsite cuts are 99% trim and fit cuts.(tapered) The tablesaw is not design for tapered cuts anyway.
The better way is the Dead Wood Concept.Find a way to secure the wood into a guide, and the means to guide your tool on the guide. Then ,the wood the guide and your tool become one with CNC like precEZon.
Edit: Now, this is something that you can make with your tablesaw.
YCF Dino
Edited 12/18/2004 9:41 pm ET by YCFriend
If your lumber yard has 2" x 3" stock, I'll bet that it's actually 2-1/2" wide. - lol
