RO sander velcro
bearmon | Posted in Tools for Home Building on October 19, 2007 02:56am
What is a good way to clean the velcro pad on a sander?  Sanding disks don’t stay on very well anymore.
TIA
Bear
  1. TomC | Oct 19, 2007 03:52am | #1
    Here is the logic: when the velcro goes there won't be much grit left, throw it out.
  2. jesse | Oct 19, 2007 04:00am | #2
    You mean the part on the sander, right? You can replace the pad. My tool repair place stocks them, at least for Porter Cable. In fact I just bought one last week - $21.
  3. FastEddie | Oct 19, 2007 04:03am | #3
    You could try picking up the dust with the sticky part of duct tape.  But chances are that the hooks are worn out.  Home Depot and Lowes stock new pads, but probably not a PC brand name.  Just buy the right diameter and number of holes.
  4. TomE | Oct 19, 2007 05:11am | #4
    As others have said, replace the pad if one is available.
    I loaned a sander out once, it came back with useless pad.
     It seems that the borrower was a little too aggressive with the sander, using excess pressure to sand "faster" and managed to overheat the pad melting the hooks.
    Last tool I ever loaned the guy.
  5. telephoneguy | Oct 19, 2007 05:43am | #5
    On a Bocsh RO sander I just removed the factory hook Velcro and bought a new pad that was made to convert a sander to hook and loop...sold @ Canadian Tire up here and was very good quality.Also when the velcro looses it hook ability it turns a RO sander into a very dangerous tool...the sandpaper disc can fly off at high speed and if your sanding a vertical surface you could get struck in the eye by the disks edge ....always wear your safety glasses when using this seemingly harmless tool !
    1. bearmon | Oct 19, 2007 06:07am | #6
      Thanks for the replies.  It is a PC, so I should be able to find a pad to fit.Bear
      1. Treetalk | Oct 19, 2007 01:31pm | #7
        Justsaw them at Lowes for PC but they also sell a kit that will do 2 sanding heads.  I converted a   PC    PSA disc. This velcro is alot better thans PC's
  6. jc21 | Oct 19, 2007 03:25pm | #8
    Still on the original pad on my old 333- I've been pretty faithful about blowing it off after using it. If that doesn't work it may be time to replace the pad. It may be heat generated by years of sanding may have damaged the velcro.
  • Sharp-Blade Solution
