Having fun with the digital camera – I want to thank almost everyone who shares their knowledge on this forum – you all are gracious and inspiring – and thanks also to Taunton for sponsoring ‘breaktime’ and also for FHB, issue #1 which I serendipitously ran across so many years ago – -anyway, DW and I moved to this non-descript, run down farmstead 25 years ago this May – and embarked on the never-ending project – what ever could be said, everyone agrees it’s been interesting – DOUD
By considering things like energy-efficient mechanicals, window orientation, and renewable energy sources, homes can be evaluated to meet the energy codes. Here's what the IRC has to say.
This is the latest phase in the never-ending project - the east wall of the 'Minnesota Room' - all the wood was cut from the property and 'woodmizered'; the paneling hs been air dried for some years, the sycamore is fresh - this wall replaces the gray, weathered plywood that has graced our lives for the last 15 years - it was a nasty wall, out of plumb with a break in it at 8' - took a lot longer to prepare the wall than to make the paneling and trim -
*another view - I'm ready to turn the corner either direction - nothing like starting in the middle - things are busy outside now, and this will have to wait on bad weather -
*here's kitchen cupboard, cherry off the farm, doors are salvage -
*door into cabin - moved the cabin in 1987 to serve as an addition - 18'X20', story and half, with 'lean to' off the south 12' deep - this was/is the west wall, the most weathered of the walls - dates to app 1850 -
*Glenwood, the Cadillac of ranges - door is butternut and poplar - table sycamore -
*walnut, ash, and poplar table I built 18 years ago - got a couple of picts of the cabinet in the background that I'll post when I figure out how to rotate the images - this camera needs a flash I guess - picts just aren't as good as I'd like -
*thanks to Luka, here's a pict that is not on its side - I have a weakness for 70's stereo that doesn't fit well with our rural poverty (honest) look - here's a project from 3 years ago -
*one more, again thanks Luka for the rotation - the back opens also, for access to the nest of snakes that inhabit the rear of such set-ups - built a pair of imitation Klisph corner horns that this equipment drives - don't know if it's vintage or kitsch or both, lots of stuff has been in and out of our lives over the last 25 years - stereo's always been in -
*let's see if this makes it visible
*and the cherry cabs touched up
*thanks, Piffin, I think - - It was just too dark without flash - I've got a different camera I can borrow in the future that does flash - need practice - of course if it shows up too crisply, the workmanship would show - maybe better if it is a little fuzzy - DOUD
*David, When you increase the brightness, you should also increase the contrast. I don't tie the two together, because sometimes it takes more contrast, sometimes less.If you would like, you can send the originals to me and I will give them a try.
*On these, I decreased the contrast while increasing the brightness. The countertop in the foreground became blindingly bright with the increased brightness. Fuzziness crept in somehow too.
