Rusty mess. (help please)
square668 | Posted in Tools for Home Building on May 12, 2008 02:07am
Just found a bucket of tools that must have been left in the rain and then put in the shop wet last fall.  The @#%$#@$#  @#$@@# @#$#@# of #%$%% is no longer with me but the rust lingers, light to heavy any ideas beside oil and a wire brush?
Thanks in advance
    Sphere | May 12, 2008 02:11am | #1
    5 gallon bucket of kerosene and wire wheels,brushes. Get most off, then PB Blaster for the stuck operating parts.
    Not much else works any better.
    1. square668 | May 12, 2008 02:12am | #2
      pb blaster?
        Sphere | May 12, 2008 02:20am | #4
        Liquid wrench type penetrating oil in a spray can, auto parts stores and Lowes carries it. REALLY good stuff, I just freed up some hyd. jacks that were frozen up real bad.Spheramid Enterprises Architectural Woodworks
  2. Sasquatch | May 12, 2008 02:14am | #3
    I have had success with Evapo-Rust.  It is sewerable, and takes light rust off fast, and deep rust within 24 hrs.  I think a gallon is about $20.  Google it.  In my last project, I built a box with some scrap lumber that fit the items I wanted to de-rust.  I lined it with some 6 mil PE, added the parts, and covered them with the product.  Next day, I took them out to the driveway and sprayed them off.  They were clean.
    I let them dry in the sun.  Then, to curb further rusting, I brushed on some clean product.
  3. Junkman001 | May 12, 2008 02:30am | #5
    I've seen (on the web) examples of a product called Ultra one.  If it works as good as they say it is it would be great.
    Mike
    Insert initially amusing but ultimately annoying catch phrase here.
    Dinosaur | May 12, 2008 03:20am | #6
    Does Naval Jelly still exist? That used to be the standard treatment.
    Dinosaur
    foolish men call Justice....
  5. brownbagg | May 12, 2008 03:22am | #7
    get some oxy clean, pour couple table spoon in the bucket, fill with water. hook all the metal tools together with jumpers. hook to battery charger. hook the other contact to a piece of scrap steel, make sure it not touching the other metal. come back in couple days, they be spotless and the paint still be good.
      IMERC | May 12, 2008 06:19am | #13
      use lye instead...
      faster...
        maddog3 | May 14, 2008 02:37am | #14
        OK , I'll bite .if a battery charger works, would a welding machine get it one faster, dial the volts waaay down and crank the amps way up.. or would it just eject the caustic all over the placejust don't know if the welder would blow a fuse.
          IMERC | May 14, 2008 04:12am | #15
          you want a reverse electrolisis type effect.....
          never tried a welder....
          can we have the film by eleven???
            maddog3 | May 14, 2008 04:13am | #16
            I think you should try it first..... !and what's with the lye ? seems kinda nasty to play with.
            IMERC | May 14, 2008 04:16am | #17
            tell me again where yur shop/garage is....
            a weak solution of lye works pretty fast...
            maddog3 | May 14, 2008 06:06am | #19
            well I'm gonna give it a try with the batt charger first.... I'm taking the yellow road first time out..... this weekend if I have the time.
            IMERC | May 14, 2008 07:54am | #21
            I use a 2 amp trickle charger...
            maddog3 | May 15, 2008 01:33am | #27
            I can do that ? Thanks M.
            IMERC | May 15, 2008 04:15am | #33
            Electroplating uses around 20VDC and little or no amps....
            so...................................
          7. User avater
            maddog3 | May 15, 2008 05:55am | #37
            hmmm,I remember running busbar for very high currents like around 2K and very low single digit voltages.
          8. dovetail97128 | May 15, 2008 07:19am | #38
            Depends on a variety of factors and what one is trying to accomplish with the plating. Both are used. http://en.wikipedia.org/wiki/Electroplating I remember that too high a amperage would cause "burn" and over deposit on the highlights of a piece being plated and sometimes they would have to be stripped and re-plated at lesser amperage.
            Sometimes the "burn" could be polished off with satisfactory results.
          9. doodabug | May 15, 2008 02:06am | #29
            You are going to need a large tank for the table saw.
          10. User avater
            maddog3 | May 15, 2008 03:33am | #31
            HAHAHahahahAhh, what is this ..... "clown week".
          11. doodabug | May 15, 2008 03:59am | #32
            Just remember to take the motor off first.
          12. User avater
            maddog3 | May 15, 2008 05:46am | #34
            if this works I'm coming over and we'll do your saw !!LMAO.
          13. User avater
            IMERC | May 15, 2008 05:49am | #35
            HEY!!!!
            what happened to using yur welder in yur gitradge????
          14. User avater
            IMERC | May 14, 2008 08:21am | #22
            ypo could use distilled vinegar...
          15. VaTom | May 14, 2008 08:22am | #23
            How do you clean your saw blades?  Mine go into the lye bucket, get their teeth brushed, rinse, and dry.  Quick and easy.PAHS works. Bury it.
          16. User avater
            maddog3 | May 15, 2008 01:32am | #26
            you have to clean saw blades ??? :)I thought they were just dull,since I don't use mine all the time I use that Boeshield stuff.
          17. VaTom | May 15, 2008 01:40am | #28
            Yup, leave 'em covered with pitch and they'll get dull.
          PeteDraganic | May 15, 2008 05:53am | #36
          that reminds me of an episode of Mythbusters.
          One of the guys tried using electrolosis to corode some metal bars but was using AC.... so in efect he would dissolve some metal and then attach some metal as the curret alternated.
          Had to use DC to get the desired effect.
          I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
          IMERC | May 19, 2008 04:29am | #40
          so what happened???
          or are you gonna start a new thread on "new" replacement garage????
            maddog3 | May 19, 2008 05:08am | #41
            well one of the string trimmers, the newest one of course, was giving me fits and so was my hip so I didn't get a roundtuit this weekend. walked past the charger about twenty times thoughbut now I think you're settin me up...... :).
            IMERC | May 19, 2008 05:24am | #42
            I was just trying to get eve.... er... ummmmmmmmm....
            hey!!! I was trying to set up anybody...
            I wasn't even there...
            ask anyone of the dogs....
            they'll tell ya.....
            sorry about the hip.. just wundering how successful you were....
            besides....
            have a special on me....
            maddog3 | May 19, 2008 01:02pm | #43
            ahaaa , thanks a lot .. pal .. I'll keep it nearby and hopefully will have a go at it this week .
    2. brucet9 | May 14, 2008 06:33am | #20
      "hook to battery charger."Which end is pos, which neg?
      BruceT
      1. dovetail97128 | May 14, 2008 08:35am | #24
        Posted earlier, has instructions. http://myweb.tiscali.co.uk/andyspatch/rust.htm#intro
      2. brownbagg | May 14, 2008 01:40pm | #25
        the scrap metal is postive
    FatRoman | May 12, 2008 03:38am | #8
    Citric acid works pretty well. As in a bottle of lemon juice and a bucket of water.
    Just restored an old plane and some ship auger bits that way and was pretty surprised. You'll probably want to hit it with a green scouring pad just to make sure, but honestly 98% of the oxidation disappears thanks to the reaction.
    One word of caution, when you take the tools out of the mix, don't let them sit around before you wipe them down and dry them off. They'll flash rust. A hair dryer works well to prevent that.
    'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
  7. User avater
    MarkH | May 12, 2008 03:42am | #9
    What Brownbagg said...
  8. DRose | May 12, 2008 04:39am | #10
    Muriatic acid was the key to naval jelly.  It's used to do something to hot tubs, so it's commercially available.  Make sure you oil the daylights out of anything you use it on.
    1. RedfordHenry | May 12, 2008 06:14am | #12
      I'm pretty certain that the active ingredient in naval jelly is phosphoric acid, not muriatic (hydrochloric) acid.  Dilute phosphoric is the expedient way to cut iron oxide.
      1. Disputantum | May 14, 2008 04:55am | #18
        You are correct, sir! Also the active ingredient in Lime Away and Coca Cola. http://en.wikipedia.org/wiki/Phosphoric_acidNothing would be done at all if a man waited till he could do it so well
        that no one could find fault with it.—John Cardinal Newman
        Disputantum Semirotten Woodworking
          Dinosaur | May 15, 2008 03:02am | #30
          From the MSDS on Permatex Corp's brand of Naval Jelly:
          Naval Jelly(R) Rust Remover812871.  CHEMICAL PRODUCT AND COMPANY IDENTIFICATIONProduct Name:              Naval Jelly(R) Rust RemoverItem No.:                  81287Product Type:              Rust DissolverNAVAL JELLY is a registered trademark of Naval Jelly Company2.  COMPOSITION, INFORMATION ON INGREDIENTSIngredients                      CAS No.               %Water                            7732-18-5           65-70PHOSPHORIC ACID*                 7664-38-2           25-30ISOPROPYL ALCOHOL                67-63-0              1-3Polysaccharide                   11138-66-2           1-3SULFURIC ACID*                   7664-93-9            1-3Surfactant                       Proprietary          1-3SILICA, AMORPHOUS, FUMED,CRYSTALLINE-FREE                112945-52-5        0.1-1* This component is listed as a SARA Section 313 Toxic Chemical.
          Dinosaur
    2. BobChapman | May 19, 2008 03:14am | #39
      Not muriatic acid, but phosphoric acid, IIRC
  9. WayneL5 | May 12, 2008 06:03am | #11
    Naval Jelly, tomato sauce, or Kool-Aid.
