Safe to use a two man auger around large tree roots?
SwissCarpenter | Posted in Construction Techniques on May 9, 2013 07:42am
I need to dig a few holes for footings for a deck in an area close to a large tree where there’s a very good probability of hitting tree roots.  Based on the size of the tree and what I’m seeing close to the surface I’m guessing that I might hit roots as large as 4″ in diameter. I’ve used a two man auger before and cut through smaller roots in clay soil with minimal kickback.  What I’m worried about is hitting a root and being thrown sideways when the auger hits the root. Do I have a need to be worried or am I going to be ok?  Sure I can dig the holes by hand, but I’m trying to avoid that if at all possible.
    MarkH | May 09, 2013 08:55pm | #1
    Be afraid, be very afraid.
    Mike_Mahan | May 09, 2013 09:34pm | #2
    Rental?
    Asuming that you don't actually own this beast, ask the rental guys.
  3. oops | May 09, 2013 09:36pm | #3
    auger
    The tree  probably shares your concerns .
  4. calvin | May 09, 2013 10:01pm | #4
    SC
    The "beaver" or some name like that, auger............with the motor off to the side and a "pto" drive-the motor is on wheels-will not "kick" you about-but you will know you hit something.
    However, there's no reverse-so-you'll need a large pipe wrench and a lengthy cheater pipe to unturn the auger from the root.
  5. florida | May 10, 2013 07:12am | #5
    Be worried, be very worried. If you hit a big root that jambs the auger someone is going to get hurt, Broken ribs, strained wrists, torn up knees. Get your post hole digger out and be safe.
  6. DanH | May 10, 2013 07:39am | #6
    We used a 2-man unit to bore footings for our deck.  No roots, but there were more than a few rocks in the soil (some fist size or larger).  Two of us couldn't control it, so our neighbor came over to help.  WIth the three of us it was barely manageable.
    They of course have a clutch, but its generally centrifugal, so it only releases after the engine slows down (which is after it's knocked you both loose and started spinning).
    You can also, in some localities, find a trailer-mounted unit to rent, or even one on a small Bobcat.  One of these would probably be safer.
  7. SwissCarpenter | May 10, 2013 10:53am | #7
    Ugh! You guys have confirmed my concerns
    The local rental yard rents a tow behind auger that seems pretty stable with a much beefer engine and is (I think) hydraulicly driven.. Better idea or am I just breaking out the shovels and digging?  I love the tree, but I'm not liking it too much these days  :-)
  8. sapwood | May 10, 2013 11:05am | #8
    not safe around here
    If you did this in our yard and hit a root from one of our trees, my wife would clobber you.
  9. junkhound | May 11, 2013 01:33am | #9
    For the price of repairing your broken ribs you can probably find an auger attachment for your bobcat on-line for less $$.
    Dont have a bobcat?  Just use your backhoe.  I dont have a hydraulic auger attachment, but pretty easy to dig hole with a bakchoe and backfill after the footing filled.  Small track hoe even better.
    Any of these options better (even if you need to buy the whole machine) than the cost of injury?
    'corse, it wont cost U mutin after bamacare takes care of you or if you are in Canukistan.
  10. User avater
    Mike_Mahan | May 11, 2013 11:31am | #10
    Jack hammer.
    I never saw a root that could stand up to a jack hammer with a spade bit.
  11. User avater
    Mike_Mahan | May 12, 2013 10:46am | #11
    Yeah, but I sure wouldn't put a footing there.
