Hey…..quick one for you guys.
Got some, rather expensive, bathroom accessories……TP holder, towel ring, etc.
The set screws seem to be working themselves loose rather quickly. Teflon tape hold em a bit longer?
ATTENTION FELLOW BREAKTIME MEMBERS:<!—-> <!—->
If you`d like to discuss topics other than home building, come on down to the Woodshed Tavern. Great bunch of guys and gals letting off a little steam about everything and anything. Its not a special club, but…..as of Monday, March 14, the Tavern folder will go behind an access wall. Only those who request access to this folder by contacting [email protected] will be able to view and participate in discussions there.
Locktite. Gonna be tough to wrap that itsy-bitsy setscrew with T-tape. Maybe put a small ding in one of the middle threads to hold it in place?
Good luck
Locktite...Great! Thanks Nick....figgered there was a product out there for the problem.
ATTENTION FELLOW BREAKTIME MEMBERS:<!----><!---->
If you`d like to discuss topics other than home building, come on down to the Woodshed Tavern. Great bunch of guys and gals letting off a little steam about everything and anything. Its not a special club, but.....as of Monday, March 14, the Tavern folder will go behind an access wall. Only those who request access to this folder by contacting [email protected] will be able to view and participate in discussions there.
Yep, Locktite. Note that there are about 4 different types, from "adjustable" to "bring a persuader" to "yeah, right" in terms of ease of turning after the stuff has set. You want something that permits removability without being too "easy".
Also note that sometimes the real problem is the stamped sheet metal bracket you're attaching too. Often they bend real easily, and other times the setup is such that tightening the set screw "pulls" the bracket away from the wall, and if there's any flex then it will work loose. It may be necessary, in some cases, to epoxy them in place (kinda plays heck with removability, though).
Thanks Dan.....got the Teflon on there now...ifit doesn`t hold, I`ll be trying the Locktite.
Hey, dude--just don't try painting the Loctite on over the Teflon!! LOL....
Dinosaur
locktite ...
dab of silicone
liquid nails/PL
wood glue.
most anything will help.
cram some sawdust in there first ... bet that works too.
Buck Construction
Artistry in Carpentry
Pgh, PA
locktite...
it's for about foever..
WOW!!! What a Ride!
Get some clear nail varnish like the ladies use. Works just the same and WAY cheaper
Everything, 100% of it, depends on how you look at it.
DW
comes with a nice little applicator brush too
locktite blue...
a bazillion other uses..
WOW!!! What a Ride!
